What version does Virtual DJ use for the NDI output? Having trouble to receive it with some programs.
geposted Fri 05 Sep 25 @ 9:49 am
v5
geposted Fri 05 Sep 25 @ 11:26 am
Thanks! It is only not sending out right on the Mac I9 (checked with NDI tools) on the M1 it's okay.
geposted Fri 05 Sep 25 @ 2:26 pm
If you mean from within VirtualDJ, and since you mentioned Syphon in your other topic, make sure that useOpengl is Off (default) since the NDI plugin only supports metal.
geposted Fri 05 Sep 25 @ 2:38 pm
