Hi all!
There is a button I'd like to change colors with a condition. This below works fine.
I can also replace the numbers with predefined colors like "red" or "white" but I don't find how to reuse the "textdarker" define done early in the skin. The define seems fine when used by itself, but I can't figure out how to use it in a script.
I assume it's pretty simple but... Thanks in advance!
color="`var '@$smcolor' ? color '#c6c6c6' : color '#727272'`"
<define color="textdarker" value="#727272"/>
geposted Sun 07 Sep 25 @ 3:03 pm
Defined colors can't be used in scripts.
You can use them in skins in EVERY place color="MyCoolColor" is supported, but not like color="`play ? color 'green' : color 'MyCoolColor'`"
geposted Mon 08 Sep 25 @ 8:54 am
Thanks Phantom
geposted Thu 11 Sep 25 @ 3:42 am
