I just updated to the latest build 8729 and now my softwre is freezing up and I have 2 back to back gigs and I need this fixed NOW - PLEASE!? I just need a link to downlioad the previous build that worked perfectly. In fact you really need to put in a SW rollback or leave the previous build where it can easily be found for this reason. Please send me the link for the previous build.
I am using a M1Mac with 32GB RAM & 1TB SSD.
804-503-0010
804-503-0010
geposted Mon 08 Sep 25 @ 11:35 pm
What you are asking for already exists (just ask and you will receive):
https://virtualdj.com/download/build.html
You should also provide more info about your problems (Controller, any other things that may be connected/running, e.g. SoundSwitch or VirtualDJ remote, other apps), source of music (internal or external drive)), so they can fix the problem.
geposted Mon 08 Sep 25 @ 11:44 pm
This same thing happened to me and I was about to have a full on panic attack with a gig in one hour and a huge wedding tomorrow.....It would open, close, open, close, open, close. It would have 8 instances of the program running on my machine and be taking up 98% of the memory. Then when it would finally stop closing on its own, it was frozen on the screen and the only way to leave it is to open Task Manager...where you could not close ANY of the running instances. That is the last time that I ever hit the button to use the updated version. I'll stick with the one I have after I had to frantically locate my initial download file from April of this year.
geposted Fri 12 Sep 25 @ 11:49 pm
I think I finally figured it out, at least for me. Its G-SYNC! Turned it off and no more issues, Build B8741 was locking up too but with g-sync off its gone.
geposted Tue 23 Sep 25 @ 6:49 pm
Hi I'm freezing too in this build, but what is G-sync?
Thanks
M
Thanks
M
geposted Sat 04 Oct 25 @ 10:36 pm
G-SYNC is an NVIDIA GPU feature. You can configure it via NVIDIA Control Panel
geposted Sun 05 Oct 25 @ 1:38 am
