I know we can backup our databases etc but am i just missing the choice somewhere to backup our settings so the things under the "options" area can be backed up etc. I hate when i sometimes have to reinstall and have to go thru all the choices and select them. if I am missing the obvious that is on me and would be excited to find that "easy button"
geposted Tue 16 Sep 25 @ 11:33 pm
Full backup and restore function is built in to the software. Details in the user manual.
geposted Wed 17 Sep 25 @ 4:57 am
ah found the info... cant be done readily
"Note : VirtualDJ settings
The settings (preferences) of VirtualDJ are kept in the settings.xml file in \VirtualDJ folder. It is suggested not to transfer this file to your new computer. The settings.xml file will be automatically created on your new computer when VirtualDJ launches for the first time. You will then need to manually change any settings to your preferences.
If the file is copied and issues occur on first launch, delete the file and re-launch"
would be nice for a easily read printout version (txt doc) so when i reinstall i know what i changed and what to change it to.
geposted Wed 17 Sep 25 @ 3:30 pm
