Can we fix the karaoke singer dropdown box so that it works like a regular dropdown box please?
It USED to work properly.
The way it should work is, when you start typing in the box, the box will populate with the singer's name. YOu should then be able to use the page up, page down, and up and down arrows to scroll through the names if desired.
Also, when you press the alt key and down arrow, the box should drop down to display names in the box.
Currently, when the box appears and you start typing into it, we can only type the person's name. It won't populate with singer's names nor will it drop down, nor can we scroll through it with arrows or page keys.
Thank you.
Thank you.
geposted Wed 17 Sep 25 @ 8:41 pm
