Topic: Mac OS 26 Tahoe
Are there any known issues upgrading to the New Mac OS 26 Tahoe?
geposted Thu 18 Sep 25 @ 1:00 am
VirtualDJ itself, works perfectly fine under Mac OS 26.
HOWEVER you should always also check with your controller manufacturer for compatibility or any driver issues on that side of the equation.
Yesterday - Clean install, 2tb base mac mini m4:
- pioneer ddj-1000 works for me
- vdj main window and vdj video output have 1px thin gray frame around their windows so I am trying to figure out how to get rid of the framing. otherwise videos, skins, etc. all running fine.
Macbook Air M3 16GB Ram, 500GB SSD intern, VDJ Library on 4TB USB4/Thunderbolt SSD upgradet from MacOS 15.
Working fine with Reloop Ready, Reloop Mixtour and SoundSwitch 2.10 and Control One.
Can confirm the 1 dot grey frame arround the Video Window with full screen on 2nd Monitor/Beamer.
But the best is Stems V2 is working now with all Modes Allways, On-Demand, Prepared, Reduced Quality, Fully Disabled without any Error Message "Stems engine GPU failed". I've been having problems with Stems V2 for over a year, ever since I switched from Macbook Air M1 to M3.
Can anyone who has already updated to MacOS 26 confirm this?
Be careful and only upgrade if you have a main computer with VirtualDJ that is working properly.
Je viens de mise à jour mon macbook pro 2020 la version mac os tahoe depuis je ne peux plus mixer pendant 5 minutes mon mac redémarre automatiquement je ne sais pas pourquoi
