hello i see a lot of issues with s4 i will go straight to the point first of all i need to use shift+jog to fast search in a song without stopping the music and to be on time like a beatjump per 4 beats if the song is playing and the second is that whenever i use start stop it is autobeatmached and its pretty annoying since i disabled it in the settings and then i saw this in the jogwheel setting when i touch it
var 'cbgadjust' ? set_bpm : var 'cbgslide' ? adjust_cbg : touchwheel what is the issue and why i cant disable auto bpm and quantize match? if i want to start the beat off time it doesnt allow me thank you for your time !!!!!
geposted Mon 22 Sep 25 @ 2:43 pm
never mind if anyone is struggling with this i put my old controller and i found the setting its this
shift_jog type this loop ? param_smaller 0% ? cycle %jog +8 & var %jog ? nothing : loop 99% 1 : cycle %jog -8 & var %jog ? nothing : loop 105% : touchwheel 'search'
shift_jog_touch type this touchwheel_touch 'search'
jog type this touchwheel
geposted Mon 22 Sep 25 @ 2:51 pm
i still have the issue of the beatmatch that its done automated if anyone knows the answer i would appreciate
geposted Mon 22 Sep 25 @ 2:52 pm
Where did you find all those mappings ?
Also automatic beatmatch has NOTHING to do with the jog.
For starters, if you use QUANTIZE, turn it off.
Also turn off "Smart Play"
Those 2 settings (among with the autoBPMMatch one) are the most common reason VirtualDJ will sync the tracks automatically
geposted Mon 22 Sep 25 @ 5:35 pm
