Topic: Sampler Editor not applying/saving BPM
Virtualdj: v2025 b8741
Windows 10 64bit: 22H2 19045.6332 & Windows 11 64bit 24H2
This could be user error but, when updating the BPM in the sample editor, the updated value is not saved. For example, when trying to double the time of a sample, I update the BPM from 126 to 252. That should, as I understand the sampler to work, cause the sample to play at twice the recorded speed.
However, when saving the sample, the BPM resets to its default value, in this case 126.
geposted Tue 23 Sep 25 @ 6:41 pm
Did you ever resolve this issue? I’m having the exact same problem: changing BPM in the sample editor does not seem to change anything.
