Hello Everyone
I’m having an issue with VirtualDJ 2025 while using hardware controllers (Denon Prime 4 and others). I work as a DJ at weddings and I often use the sampler.
Here’s the problem:
• When I trigger samples from the VirtualDJ laptop GUI, they sync correctly with the Master Deck BPM, just like in VDJ 2024.
• However, when I trigger the hardware sampler pads on any controller, they do not sync with the other deck even when the Master Deck changes.
• In VDJ 2024 (Build 8350), everything worked perfectly — one sampler followed the active deck automatically. In VDJ 2025, it seems each deck has its own sampler, and the pads are strictly tied to the deck they are assigned to.
• I’ve tried adjusting samplerMasterDeck = Master and samplerBeatSync = Yes, but the hardware pads still do not sync automatically.
Is there a way to restore the 2024-style global sampler behavior in VDJ 2025 for hardware controllers, or a workaround so the pads follow the active/master deck BPM like before?
Thanks in advance!
Here’s the problem:
Thanks in advance!
geposted Tue 23 Sep 25 @ 8:53 pm
When you right-clicking the sample bank you have active, do you see it marked as Stem Swap? If so, try disabling that.
Read more here
https://virtualdj.com/forums/261521/General_Discussion/%5BNEWS%5D%3A_VirtualDJ_2025_-_with_StemSwap_sampler.html
Make sure that the Master Deck is what you think it is - often times that is changed when the audible channel is changed (e.g. full crossfade to the other channel using the controller).
Read more here
geposted Tue 23 Sep 25 @ 9:33 pm
Yes I have tried Disabling Steam swap, i tried everything I think is update on virtual if i roll back to Build8350 the problem is solved, but I want to try new features of virtual so im stuck in B8350
geposted Tue 23 Sep 25 @ 9:49 pm
I just tested this myself and I have to agree, there is some inconsistency that I saw (I tried this with the I Know This built-in sample bank (Non Stem Swap))
- With no controller connected, it seems to sync samples correctly
- When I connected my DDJ-1000
- If I trigger samples from a deck that isn't the master deck, some samples sync (e.g. Nation) and some don't (e.g. Clap).
If I trigger the samples on the same deck as the master deck, then they all sync properly
geposted Thu 25 Sep 25 @ 11:23 pm
DJ VINYLTOUCH Thanks for your reply
I hope VDJ Will Solve this, Like me, there are many DJs in Albania who are stuck on B8350. Because of this, it would be a good thing if VDJ fixed this, so that I and others can enjoy the new updates and innovations of VDJ.
geposted Thu 25 Sep 25 @ 11:52 pm
In the meantime - just switch to the sampler on the master deck and trigger it there.
geposted Thu 25 Sep 25 @ 11:54 pm
Thank you I will Try it
geposted Fri 26 Sep 25 @ 12:01 am
Yes it Works as you said, But This is a big problem for live use, because during weddings I need to trigger samples quickly without worrying which deck is Master. Switching sampler banks every time the Master deck changes is not practical.
geposted Fri 26 Sep 25 @ 12:17 am
I suggested a workaround, not a solution fix (devs probably need to fix that bug).
geposted Fri 26 Sep 25 @ 2:08 am
Thank you very much for your time, I hope They see this and fix this Issue
geposted Fri 26 Sep 25 @ 11:21 am
As another workaround, you could edit the sampler pad page, and change
to
(and the same for the other pads)
sampler_pad 1
to
deck master sampler_pad 1
geposted Fri 26 Sep 25 @ 11:41 am
ADION, Thank you for your reply, i Just Tried this And Still same thing again
geposted Fri 26 Sep 25 @ 5:11 pm
I have the same exact problem and i couldn t resolve it. The solution was to downgrade to version 8350.
I hope the devs see this and fix this bug. A lot of us are now stuck to the old version that works corectly
geposted Tue 30 Sep 25 @ 11:30 pm
Andreas, Thank you for your reply, I talked with Vdj Support team and solved this problem just check in your Early Access Update
geposted Sat 04 Oct 25 @ 8:52 pm
