Hello everyone
My Vestax vci-400 has pads. I want to use one hotkey page and three sample pages in the pad settings. I want the sample pad button on the pad controller to light when a sample is present and blink when it's playing. I can see this on the button LED in mapping like this:
<code>sampler_loaded 1 ? sampler_pad 1 ? blink 300ms : on : off</code>
But then the loop display on the loop page doesn't work. How can I do this? Can I do this in the pad settings?
geposted Wed 24 Sep 25 @ 9:13 pm
deck master sampler_pad 1 ? blink 300ms : on : off
geposted Wed 24 Sep 25 @ 10:41 pm
Thanks for the answer!
Should this be written in the LED mapping or in the pad settings?
geposted Thu 25 Sep 25 @ 7:10 am
Let me try to clarify the question.
Virtual DJ has a pad settings menu, and there's a "color" section. Can I set the blinking there? Or does it only affect the interface display?
geposted Thu 25 Sep 25 @ 12:35 pm
What my attempts led to:
I'm trying this in pad editor, sample page:
sampler_play_stop 8
Drawbacks: The pad doesn't light up when the sample is loaded. It lights up when playing. Playback works when I press the pad.
This displays the way I want:
sampler_play 8 ? blink 300ms : sampler_loaded 8 ? on: off
But playback on the button doesn't work.
I'm trying to combine these:
sampler_play_stop 8 & sampler_play 8 ? blink 300ms : sampler_loaded 8 ? on: off
or
(sampler_play_stop 8) & (sampler_play 8 ? blink 300ms : sampler_loaded 8 ? on: off)
as well as other combinations, it doesn't work at all. What am I doing wrong, what can I do?
sampler_play_stop 8
or
geposted Thu 25 Sep 25 @ 1:29 pm
i do it!!!!
This code work
sampler_play 8 ? blink 300ms & & sampler_stop 8 : sampler_loaded 8 ? on & sampler_play 8 : off : nothing
This code work
geposted Thu 25 Sep 25 @ 1:44 pm
