Topic: 4 decks effect switch
Hello.
I'm trying to create a decent reverb for the umpteenth time and seem to have succeeded. I found a free reverb called Sabrina with good starting parameters and which can be controlled via effects. On one deck, it looks like this:
soft start and soft fade-out
var '$Lreverb_on' ? set '$Lreverb_on' 0 & deck 1 effect 'Sabrina' slider 1 0 & repeat_stop RevDN & deck 1 effect 'Sabrina' enabled & repeat_start RevUP 10ms 50 & deck 1 effect 'Sabrina' slider 1 +5% & (deck 1 effect 'Sabrina' slider 1 50% ? repeat_stop RevUP:nothing) : repeat_start RevDN 80ms 50 & deck 1 effect 'Sabrina' slider 1 -1% & (set '$Lreverb_on' 1 & deck 1 effect 'Sabrina' slider 1 0 ? repeat_stop RevDN )
But since I have two decks on each side and only one effects unit, I switch it to one deck. I'm trying to do this, but it doesn't work:
var '$L_Side' ? var '$D3reverb_off' ? set '$D3reverb_off' 0 & deck 3 effect 'Sabrina' slider 1 0 & repeat_stop Rev3DN & deck 3 effect 'Sabrina' enabled & repeat_start Rev3UP 10ms 50 & deck 3 effect 'Sabrina' slider 1 +5% & (deck 3 effect 'Sabrina' slider 1 50% ? repeat_stop Rev3UP:nothing) : repeat_start Rev3DN 80ms 50 & deck 3 effect 'Sabrina' slider 1 -1% & (set '$D3reverb_off' 1 & deck 3 effect 'Sabrina' slider 3 0 ? repeat_stop Rev3DN ):nothing : var '$D1reverb_off' ? set '$D1reverb_off' 0 & deck 1 effect 'Sabrina' slider 1 0 & repeat_stop Rev1DN & deck 1 effect 'Sabrina' enabled & repeat_start Rev1UP 10ms 50 & deck 1 effect 'Sabrina' slider 1 +5% & (deck 1 effect 'Sabrina' slider 1 50% ? repeat_stop Rev1UP:nothing) : repeat_start Rev1DN 80ms 50 & deck 1 effect 'Sabrina' slider 1 -1% & (set '$D1reverb_off' 1 & deck 1 effect 'Sabrina' slider 1 0 ? repeat_stop Rev1DN )
I'm trying to do this because I have a four-deck console and I want to route the effects unit to one or the other depending on which is currently active.
It's clear the code is redundant. Is it possible to substitute a variable with the deck number in the deck selection? for example:
... deck `$deck` effect 'Sabrina' slider 1 0 ... ??
I haven't found a way to do this anywhere, and experiments show that the variables can only be 1 and ?
Sorry about the formatting. I don't know how to format the code correctly and I couldn't find any instructions on how to do it anywhere.
geposted Tue 30 Sep 25 @ 1:11 pm
