got a message to install new update so i did and wished i never everything was running great now it plays two songs and crashes
BUILD 8752 (2025-09-29)
-Fix SoundCloud downloads stopping early in some cases
-Fix macOS 26 showing border on windows
-Fix sync-start for samples not working with drops
wont play auto mix two songs in crashes
geposted Sat 04 Oct 25 @ 8:34 am
No crashes appear to be logged.
Can you try with 8769?
https://virtualdj.com/download/build.html
geposted Sat 04 Oct 25 @ 10:32 am
still crashing after installing 8769
this only when using dezzer on auto mix it stared after the update
locks up then i have to close it all down wont send any crash data
geposted Sat 04 Oct 25 @ 11:37 am
need a fix for this as i cant use it
And as soon as I play a song it's coming up with stems in the middle of the screen as I not even push the button this update has killed my vdj
geposted Sat 04 Oct 25 @ 5:41 pm
Can you try with build 8800?
geposted Tue 07 Oct 25 @ 11:55 am
