Hello,
I am using a Hercules Inpulse 500 with vdj and yesterday my settings disappeared, meaning skin, the pad customizations, some keyboard shortcuts I defined,. audio profiles. The "my lists" is ok.
I tried to restore previous backups but it does not work. I am really desperate. What else can I try?? Where the hell are those settings stored?
Thanks for any help!
geposted Sat 04 Oct 25 @ 3:59 pm
The serrings.xml file is the one that stores that info. It is located in the virtualdj home folder.
geposted Sat 04 Oct 25 @ 4:56 pm
