Topic: Compressor plug-in
Hey whats the compressor plug-in mostly used for? I was thinking its good for removing clippings in some songs. How do I use this plug in? I have a few songs that needs clippings removed.
geposted Mon 06 Oct 25 @ 1:59 am
You've got it wrong.
Compressors (when used properly) PREVENT clipping from occurring. They do not remove it.
Actually, once clipping occurs in a signal there's no way to remove it
Finally VirtualDJ has a built in limiter (special kind of compressor) to prevent clipping if you overdo it with gain, and therefore a compressor in general is not needed.
So what your saying is that you don't use the plugin and you just use Virtual dj built-in limiter right?
Yes. For 99.9999999% of cases that's enough.
