Forum: Music discussion
Topic: Deezer playlist completely deleted. HELP!!!!
I had saved up a massive playlist that took me months. I had it in my automix but it had become messy and duplicated so I removed the tracks but it has deleted the tracks from my Deezer playlist. I can't recover it from Deezer because it was not a complete playlist that was deleted, only the vast majority of tracks in it. Is there any way to retrieve this?
geposted Fri 10 Oct 25 @ 9:44 pm
Did you select Delete, Remove from DB or remove from this list? If you chose remove from DB, you can retrieve a DB backup first and also use the history to find a day you played the playlist to rebuild it from there.
