When activating /deactivating STEMS ECHO and STEMS REVERB the track skips a 1/2 to 1 beat .
I was on 8800 , I rolled back to 5678. No change .
I
-RANE PERFORMER
-MACOS
I
-RANE PERFORMER
-MACOS
geposted Mon 13 Oct 25 @ 12:37 pm
I was really bummed at this . Was totally fine for so long then suddenly while On Air. If there is no resolve I’ll have to leave VDJ . Which I do not want to do at all.
-RANE PERFORMER
-MACOS
-RANE PERFORMER
-MACOS
geposted Mon 13 Oct 25 @ 2:47 pm
That's probably the delay added from the FX Send/Return process.
Can you try with setting fxProcessing to Pre-fader and perhaps remove the deckfxreturn and deckfxsend lines in Audio setup ?
geposted Mon 13 Oct 25 @ 5:06 pm
I tried it. No change . Very odd.
geposted Tue 14 Oct 25 @ 2:47 am
I wonder , is it possible that my issue could be track related.
When I try out the same track on tidal seems ok.
I tried some other tracks might be ok .
Basically I had a batch of tracks that I was using , about 50 for a radio set . All newly downloaded , I had an issue with a lot of those tracks .
But when i test out the same tracks on tidal seems ok. Does that make sense to you ?
geposted Tue 14 Oct 25 @ 12:22 pm
