Dear everyone,
I’m having a problem with my Pioneer FLX10 controller. Specifically, here’s what’s happening:
Within the pad section, when I select Pad FX — I tried both the original settings and creating new ones — I managed to set Pad 7 to Echo Out and Pad 8 to Reverb, and everything worked great. Then I set Pad 6 to Break Start, and that also worked perfectly, both on the left and right decks, using the Custom mode.
However, when I switched to the 4-deck mode, everything still worked fine on Decks 1 and 2. But on Decks 3 and 4, Reverb and Echo Out work perfectly, while Break Start doesn’t do anything.
I tried adjusting some settings, but now everything is completely messed up — when I press Break Start on Deck 3 or 4, it triggers Echo Out instead.
Could you please help me fix all these problems and set up my device so that it works simply and properly?
geposted Tue 14 Oct 25 @ 11:45 pm
HOW you "managed to set X pad do Y thing" matters a lot.
So let us know what did first. Try to provide as many details as possible.
geposted Wed 15 Oct 25 @ 8:46 am
I will send video so you can see, i asked and chat gpt for help, but still had lot of issues ,so i will record it all
geposted Wed 15 Oct 25 @ 12:44 pm
Chat GPT isn't going to help with a specific problem on a specific controller with specific software.
geposted Wed 15 Oct 25 @ 12:46 pm
Yes , chatgpt isnt helpful, so please look and help me with this problems , see youtube link ( firmware is new 1.14 i think )
https://youtu.be/x2n5TulU5fs?si=va_6ArEhtKnawZI-
geposted Wed 15 Oct 25 @ 3:35 pm
You're not controlling named effects, you're controlling effect slots.
Read this.
https://virtualdj.com/forums/223743/General_Discussion/Script_School.html?page=1.35
Read this.
geposted Wed 15 Oct 25 @ 5:22 pm
I saw this post but I didn’t figure out what to do, can someone please make some video instructions , whats i need to do ? 🙏
geposted Wed 15 Oct 25 @ 8:28 pm
Not clear which Pads page is called from Decks 1 , 3. Is it PadsFX or some other "custom" ?
Can you post the content of your PadFX.xml or Custom.xml (or some other name you have in your /Pads folder ?
For your other issue (Deck 3 not starting), can you assign a skin Custom button as touchwheel_touch and see if it is enabled on Deck 3 while you experience this issue ?
One explanation about the FXs not triggered properly would be the "dual Deck mode" enabled when SHIFT+DECK sel buttons is pressed and applies to several controller buttons incl Pads. One easy way to know if enabled is to map a skin custom button as dualdeckmode and see if enabled at that time.
geposted Thu 16 Oct 25 @ 7:44 am
Finaly works , guys thanks for help , thank you a lot .
geposted Thu 16 Oct 25 @ 8:54 pm
