Has anyone else noticed that the Slicer Hold is no longer functional?
geposted Sat 18 Oct 25 @ 5:55 am
What is Slicer Hold, and what exactly isn't functional anymore?
geposted Sat 18 Oct 25 @ 6:00 am
SLICER
Slicer provides the ability to slice up a track similar to a loop roll. The track is divided into 8 steps (1 beat by default) that move along with each beat (step) of the track. Pressing each Pad will loop (slice) the last displayed step. When the pad is released, the track will continue to play from the position that it would have been in as if nothing happened at all.
Right clicking (shift) the pads will provide Slicer Hold mode. This memorizes the Slice so it can be easily returned to at a later point without disrupting the tracks current position
geposted Sat 18 Oct 25 @ 8:04 pm
Discontinued, use Serato or Rekordbox is you need this functional
geposted 11 hours ago
All it needs is a bit of a pad page tweak or the devs to fix the slicer N "hold" verb, moving sw because of this is like moving house because a lightbulb needs changing.
geposted 9 hours ago
