I'm considering an operating system switch to Linux based Zorin OS instead of buying new computers that Windows 11 would be happy with. Supposedly, Zorin OS emulates Windows quite well, but I just wanted to ask here and see if anyone has actually tried it with VDJ. Thanks in advance!
geposted Thu 23 Oct 25 @ 4:57 am
No, I don't think you'll find someone who's tried it.
Also we've said it numerous times that the MAIN issue is not VirtualDJ itself (it already runs on some distros under Wine), but the drivers of any DJ gear you may want to use, and of course the Stems Engine.
If you are serious about DJ-ing then forget about Linux and get yourself a Windows PC or a MAC. Period.
Otherwise you can try it, but the results will most likely be mixed.
geposted Thu 23 Oct 25 @ 6:59 am
I understand that there are fewer drivers on Linux, but my controller is supported. (eg I can use it as a sound card, and as a MIDI device) And many are supported as well. Moreover, until somebody brings a DJ software, how can device providers be interested in bringing drivers to their devices?
geposted Wed 03 Dec 25 @ 4:53 pm
There is DJ software (Mixxx), but you'll see once you start talking about hardware, everything falls down.
Maybe you should start with reading their hardware support docs to see how hard the problem is.
Once you have consistent uptake with hardware makers on Linux distributions, it then becomes feasible for a DJ software team to look into porting to Linux distributions. For any software offering, the supported platforms chosen always depends on all of the parts of the ecosystem that surrounds. The DJ world is heavily hardware centric, and hardware makers aren't making the effort to port to Linux distributions for the vast majority of their professional line of hardware.
This is different from like say, a DAW like REAPER - the focus is much more on software capability - the hardware often not required to do the job professionally.
Add to that problem, there are many distributions, so you have to choose the few you want to support, and most DJs aren't tech savvy enough to even use mainstream OSes like Windows/MacOS, then you add a Linux distro into the mix (tons of variables in terms of configuration, setup, Desktop Environment, etc) - you could imagine the confusion with supportability just with that.
Summary: Your issue is not with DJ software providers, it's with hardware makers (if they made all hardware class compliant, to start, the story could be different).
geposted Wed 03 Dec 25 @ 5:13 pm
So I can confirm that VirtualDJ works on ZorinOS. I have a Hercules RMX2 Black & Gold Edition controller that worked for it as well. There are a couple things to do though:
1. In ZorinOS, disable animations.
2. In VirtualDJ go to Settings>Performance and disable experimentalSkinEngine.
3. Install the drivers for the controller like you would on Windows.
4. Plug in your controller and bring up VirtualDJ, which should bring up a message asking about if your speakers are connected to the computer or controller.
When I first installed VirtualDJ, I ran into a bug that caused parts of the screen to flicker with the timing pulse of the UI. I went to forums and ChatGPT looking for possible fixes, and then delved into the Settings one by one. the experimentalSkinEngine being disabled stopped the flickering immediately and haven't had it since. I thoroughly tested my controller with it connected and it had zero issues. All controls worked as they did in Windows.
Posting this to pay it forward and hoping it helps someone else. Good luck to you all!
geposted Thu 16 Apr 26 @ 10:22 pm
That (the answer from PhantomDeejay at the beginning) is a bit of an overstatement.
Yes, Linux can have limitations with some DJ hardware and proprietary software, but turning that into “just use Windows or Mac, period” is not really a technical argument — it’s just defaulting to the mainstream option.
In this case, for example, complynx already confirmed their controller works as an audio interface and MIDI device, which is the main hurdle. So the blanket advice doesn’t really apply here.
And more importantly, dismissing Linux entirely just because it’s not the dominant commercial platform ignores the whole point of open systems: flexibility, control, and the ability to build working setups outside of vendor lock-in. That’s not “less serious”, it just requires a bit more awareness of your tools.
If the workflow works, it works — regardless of the OS.
“Period.” doesn’t really add anything.
As conclusion, thanks Brandon Spradling for the confirmation on Zorin :)
geposted Wed 22 Apr 26 @ 12:29 pm
So his discovery doesn't change anything on the original summary.
If you want a shortcut to a list that of controllers and audio interfaces that might work, check any DJ software page that claims to support them on iOS (implies compliance), then take a look at all that doesn't work.
For the vast majority of professional controllers one or more of the conditions stated in 2) is false, and it doesn't make sense for a (perhaps small) team of devs to port and support the application to work there, especially given one of the goals is to support as much hardware across the platforms as equally as possible (it really isn't that hard to understand) - that is what matters, not that you can find select cases were it might work (and probably could have its own issues based on the method used).
Get the hardware vendors to agree to complete compliance first going forward, then ressurect this thread.
- Zorin uses Wine for Windows app emulation
VirtualDJ can probably run there. - The controller he identified is most likely MIDI compliant. The audio part may or may not be compliant, or there may have been support added to the Kernel for it in ALSA
Wine normally does not provide emulation support for these kind of drivers (i.e. the driver installation step most likely failed or did nothing towards the verification situation).
geposted Wed 22 Apr 26 @ 1:19 pm
So is the worry that these professional controllers have proprietary drivers specifically in relation to their onboard audio interfaces which could be incompatible with Linux?
I haven't been fortunate enough to use expensive "professional" tier gear, whatever that entails, but so far I have 2 MIDI class compliant controllers, both with internal sound cards, that worked just fine through alsa/pipewire which is the modern standard in Linux. No need to even install ASIO drivers and such to mimic more of a Windows setup in any compatibility layers I've tried (Lutris, Bottles, Wine11)
Assuming that for the most part, most controllers out there are class compliant and, barring some specific proprietary drivers for internal audio interfaces in them, I should guess that there are plenty more controllers on the market that should work just fine.
For the record, I've tested a Reloop Mixtour and an RMX2. I'm guessing plenty of people use such tiers of controllers so the benefit of being able to run on Linux can actually serve a large number of people. I'm sure the majority of Virtual DJ users aren't, in fact, high tier career DJs using expensive, professional hardware. Whether or not Virtual DJ decides to support Linux officially or not, being able to run it low latency a sI've been able to thru these powerful compatibility layers is a gamechanger for many the way I see it.
geposted Mon 04 May 26 @ 4:56 pm
Yeah — that’s a big part of the worry, but it’s not the whole story.
Audio / “professional drivers”
On Windows, a lot of controllers ship an installer that looks scary (ASIO, Control Panel, etc.). On Linux, for class-compliant devices you usually don’t need any of that:
• USB audio → ALSA / PipeWire
• USB MIDI → ALSA seq / PipeWire
So if your Reloop Mixtour and RMX2 already show up as a sound card + MIDI and work under Wine/Lutris/Bottles: you’re not imagining it. That’s exactly how it should work. No ASIO required; PipeWire is the modern path and can be excellent.
Where things get proprietary (and Linux gets ugly) is more like:
• Interfaces that only talk through a vendor Windows driver (not standard USB audio class)
• Old FireWire / special ASIO-only stacks
• Some “pro” boxes that pretend to need a driver even when part of the device is class compliant
Not every expensive controller is non-compliant, and not every cheap one is compliant — but your guess is right: a lot of mid-tier and many pro units are class compliant for audio+MIDI, so a large chunk of VDJ users could already run on Linux for “deck + sound” without waiting for vendor Linux drivers.
The other walls (beyond the sound card)
Even when audio+MIDI are fine, VirtualDJ can still misbehave under Wine for other reasons:
1. How Wine presents MIDI to VDJ (names / VID-PID) — factory controller defs may not bind the same as Windows.
2. Screens / jog displays / “imagesysex” — private paint protocols. Class compliance does nothing for that. Device shows up; screens stay logo.
3. Stems / GPU / skin engine — software side under Wine, not “driver.inf”.
4. Timecode / some HID-only or vendor-specific control — case by case.
So:
Worry #1 = proprietary audio drivers → real for some gear, overstated for all gear.
Worry #2 = “does VDJ’s Windows brain fully wake up for this device under Wine?” → separate problem.
On your bigger point
Agree completely: most VDJ users aren’t on flagship multi-thousand stacks. Reloop / Hercules / Numark-class gear is exactly where Linux+Wine+PipeWire is already a gamechanger — low latency, no Windows tax, hardware just works as a sound card + MIDI.
I’ve pushed further on a Numark NV (class-compliant Control/Audio/Graphics): pads + audio were the easy part; dual LCDs needed extra open tooling so factory VDJ display paint would bind under Wine. Pack if anyone cares:
https://github.com/shaneodoo/NumarkNV_Screens_VDJ_Linux
But your core assumption stands: plenty of controllers should work fine on Linux for real DJing, and class compliance is the right first filter. Official VDJ Linux would be nice; until then, Wine/PipeWire isn’t a toy for a lot of us.
geposted 6 days ago @ 6:09 am
