Hi
I'm trying to map functions to an external midi pad Donner Starrypad. I can map ok the problem I'm having is I can only get it to map to one deck or the other but not individually to each deck if that makes sense? If I select a pad I want to map to and use the easy map pointer, if I do this for both decks not matter which I have selected 1,2,left,right or automatic it will only work one deck, the first one I selected on both both pads that I've mapped to
Any advice would be greatly appreciated.
geposted yesterday @ 9:17 pm
Use deck X before the action
Examples: deck 1 play deck 2 loop deck left sync deck right stop e.t.c.
geposted 14 hours ago
Thank you Sir ,
That solved my issue, I also don't know why the forum has listed me as a home user on my post?
I may have more questions about mapping when they occur if that's ok?
Wayne
Wayne
geposted 3 hours ago
