Hello VirtualDJ Development Team,
I am writing as a long-time VirtualDJ Pro user and recent owner of the AlphaTheta XDJ-AZ. First of all, I want to thank you for the incredible progress VirtualDJ has made in supporting modern Pioneer and AlphaTheta hardware — especially the XDJ-RX3, DDJ-FLX10, and the latest units.
However, I’d like to kindly request full HID and touchscreen support for the new XDJ-AZ controller.
At the moment, the unit is recognized and functional at a basic HID level (waveforms, time display, basic browsing), but the touchscreen interactivity — such as track browsing, waveform touch navigation, and FX parameter control — is not yet active within VirtualDJ.
The XDJ-AZ is an outstanding all-in-one system designed for professional use, and enabling full integration would make VirtualDJ an even more powerful and flexible platform for DJs who prefer your software but love the hardware experience of AlphaTheta.
If collaboration with AlphaTheta is required to unlock the HID display protocol, I and many other users would strongly support that move. The demand for this controller’s full compatibility is growing rapidly, and it would be amazing to see VirtualDJ lead the way in making it happen.
Thank you for continuously listening to your community and providing updates that make our workflow better with every release.
Sincerely,
A dedicated VirtualDJ Pro user and XDJ-AZ owner
Sincerely,
geposted Wed 05 Nov 25 @ 12:14 pm
Everything that the unit offers in PC control mode is already supported, including scratch and overview waveforms, touch access on selected areas/functions (limited by the device firmware) and of course library display (as designed by AlphaTheta for PC control mode)
In other words:
The device is limited by it's firmware.
If you want more functions in PC control mode, please ask Pioneer/AlphaTheta to unlock/implement them on firmware level.
PS: Please don't start multiple threads for the same subject.
It serves no purpose at all.
In other words:
geposted Wed 05 Nov 25 @ 12:28 pm
، : "Hello, I'd like to share some suggestions for improving Virtual DJ. First, I suggest enhancing the waveform's appearance and colors to make them more clear and aesthetically pleasing. Second, I hope the pre-listening feature for tracks can be simplified to be similar to Recordbox, where you can directly listen by clicking on the waveform next to the song name. Additionally, regarding the sync button, I suggest it be developed to function similarly to other software, where pressing it again releases all associated features such as Pitch Lock, Smart Play, and Smart Cue, which would simplify the process compared to the current method that requires additional steps. Furthermore, I'd like to praise the current interface, which is excellent and sophisticated, demonstrating the high quality you have reached." ؟
geposted Thu 27 Nov 25 @ 1:52 pm
Subject: Enhancing the Sync Button in Virtual DJ
Dear Virtual DJ Development Team,
I would like to discuss improving the Sync button functionality in your program. I’ve noticed that the way the Sync button works in Virtual DJ differs from other software like Rekordbox, Traktor, and Serato. In those programs, the Sync button is straightforward: pressing it once synchronizes the tracks, and pressing it again releases the sync easily.
I would also like to mention that Virtual DJ already has features like Auto Pitch Lock, Auto Match BPM, and Auto Sync (Smart Play). Why not combine all these features into the Sync button itself? This would mean that pressing Sync would activate all these features, and pressing it again would release them, just like in other software. This approach makes the process straightforward and user-friendly, especially for those transitioning from other platforms.
It’s important to make the experience as easy as possible. We, and many other users, would appreciate a Sync button that works consistently across all platforms. This is a simple enhancement that can be done easily, without the need for complicated mapping or extra steps.
Thank you for your efforts, and I look forward to your response.
Best regards,
Virtual DJ pro
geposted Mon 08 Dec 25 @ 10:02 am
Just FYI:
VirtualDJ had a "SYNC" button more than a DECADE before Pioneer and Rekordbox considered to include it on their gear.
So, why do you think VirtualDJ should adjust how sync works to match "Rekordbox" and not the other way around ?
Sync in VirtualDJ is a MOMENTARY ACTION, not a deck state. In VirtualDJ you press "SYNC" and it adjusts tempo & phase to match the other deck, the moment you press the sync button
After that moment passes, sync does nothing. There's no need to "disengage" it. Because it's not engaged. It's not a state.
Also there are other actions (that also predate Pioneer's "sync" button and behavior) that are a "state" and effectively can have similar behavior to Pioneer's "sync" if you like it that much.
Like "beatlock" for instance.
The power of VirtualDJ lies exactly in the fact that if you don't like something you can map it / remap it to something else.
So if you don't like how the SYNC button behaves on your AZ with VirtualDJ you can remap it to beatlock.
Finally, if you like VirtualDJ so much and you wish to discuss suggestions for improvements, please also consider to purchase a valid license to support it's developers.
Thank you!
Thank you!
geposted Mon 08 Dec 25 @ 10:36 am
Dear Virtual DJ Team,
I am writing to you as an existing and genuine Infinity Pro license holder. I recently made the transition to Virtual DJ after previously using Traktor.
Given my background with other DJ software, I am encountering many differences in the workflow and features. I would appreciate it if you could provide some insight into the core design philosophies and reasons behind these variances.
My registered email for the Infinity Pro license is: dj.mo2mn.xdj.az@gmail.com. Please check your records to verify my license."
geposted Mon 08 Dec 25 @ 12:59 pm
Subject: Technical Inquiry: Custom Sync Behavior and VDJScript for Traktor Workflow
"Dear Virtual DJ Team,
I am contacting you to follow up on the specific issue regarding synchronization results. I believe the functionality I require—which replicates the sync behavior I was accustomed to in other software—is available in Virtual DJ, but is not implemented by default.
I understand that achieving this outcome likely requires the creation of a custom macro or mapping, particularly concerning features like 'Automatic Smart Play' and other related functionalities.
My goal is to create a single, custom command: When I engage the Sync button, I wish for it to simultaneously activate all of these related Smart features, and when I disengage it, I want it to turn all of them off.
As a user transitioning to Virtual DJ who is reliant on this specific 'muscle memory' and synchronization method, could you please provide detailed guidance on the necessary VDJScript or Actions? Specifically, how can I modify my controller mapping to successfully implement this combined toggle function for all the relevant sync/smart features on my existing hardware?"
geposted Mon 08 Dec 25 @ 1:06 pm
Hello VirtualDJ Team,
First of all, thank you for creating such a flexible and powerful DJ platform. One of the reasons many DJs choose VirtualDJ is the freedom provided by scripting, custom mappings, and advanced configuration options.
I would like to suggest an optional feature related to Sync behavior and Master Deck protection.
My suggestion is not to change the current Sync system. The existing behavior works well for many users and should remain the default behavior. Instead, I would like to propose an additional optional setting that is disabled by default.
For example:
Protect Master Deck Ignore Sync on Master Deck Master Deck Never Follows Other Decks
The exact name is not important. The idea is that when this option is enabled, the current Master Deck can never be forced to follow another deck through a Sync command. Instead, other decks would always follow the Master.
The reason for this request is not technical convenience, but live performance safety. During weddings, clubs, festivals, and other live events, DJs work under pressure, in low-light environments, and often need to react quickly. Accidental button presses happen to everyone, including experienced DJs.
Many DJs coming from other software platforms are accustomed to a workflow where the Master Deck acts as a protected reference deck. If Sync is accidentally pressed on the currently playing Master Deck, the live track remains safe and the other deck follows the Master instead.
Importantly, this feature would be:
Disabled by default. Fully optional. Not disruptive to existing users. Compatible with the current Sync philosophy. Useful for advanced users who want additional protection. Potentially accessible through scripting and mapping for custom workflows.
This would allow VirtualDJ to support both styles of workflow:
The current flexible Sync system. A protected Master workflow for users who prefer it.
I believe this small optional feature could improve confidence during live performances while preserving complete backward compatibility with existing setups.
Thank you for considering this suggestion and for your continued work on VirtualDJ.
For example:
geposted Sun 31 May 26 @ 4:53 pm
In real-world live situations, accidental Sync presses are far more common than many people think. A DJ may be working in a dark booth, handling requests, watching the crowd, adjusting audio levels, and preparing the next track simultaneously. In these situations, protecting the currently playing Master Deck can help prevent unintended disruptions during a performance.
This is why I believe an optional Master Protection feature would be valuable. It would not replace the current Sync system, but simply provide an additional workflow for DJs who prefer a protected Master Deck approach.
geposted Sun 31 May 26 @ 4:55 pm
So map your button to do that
masterdeck is something that can be queried, if true do nothing, if false sync
geposted Sun 31 May 26 @ 5:20 pm
Subject: Feature Request & Feedback: Pushing the Limits of XDJ-AZ Integration with VirtualDJ
Dear VirtualDJ Team,
I am writing to express my appreciation for your continuous work in supporting leading DJ hardware. As a professional DJ using VirtualDJ alongside the AlphaTheta XDJ-AZ, I truly value having the power and flexibility of your software paired with a top-tier flagship unit.
While we understand that certain hardware features—such as the physical Link Cue button—are currently restricted by Pioneer/AlphaTheta at the firmware level, we also know how incredibly capable VirtualDJ’s audio engine and scripting system are. Because both the XDJ-AZ and VirtualDJ represent the pinnacle of hardware and software, our community always aspires to get the absolute most out of this setup.
With that in mind, I would love to suggest exploring alternative or creative software implementations to bridge these gaps and unlock even more potential:
Software-Based Track Previewing: Since the physical Link Cue button is locked on the hardware side, could VDJ introduce a dedicated workflow (e.g., via a long-press on the Browse encoder or custom Pad page) that activates a seamless preview deck routed directly to the headphones?
Enhanced Screen Integration: Taking full advantage of the XDJ-AZ’s 10.1-inch display and jog screens—such as displaying richer Stem-separated waveforms, advanced key information, or customizable visual overlays.
We choose VirtualDJ because it never settles for the status quo and consistently pushes technological boundaries. We hope to see even deeper integration and creative workarounds for the XDJ-AZ in upcoming updates.
Thank you for your dedication to the DJ community and for always listening to user feedback!
Best regards,
Best regards,
geposted 2 hours ago
There is no headphone channel to route to.
If the device offered customisable device skins one would have been made.
Subject: Request for Former Traktor Users: A One-Click Option for Continuous Sync & Pitch Lock
Dear VirtualDJ Development Team,
I am writing to share important feedback as a long-time former Traktor user who recently moved to VirtualDJ. First of all, we love VirtualDJ and truly appreciate the work you put into making it the most powerful software on the market.
However, there is a major challenge that many of us face when transitioning from Traktor: the Sync behavior.
In Traktor, pressing Sync is a simple, one-click action that locks everything continuously (tempo, beat grid, and pitch lock). In VirtualDJ, the default Sync is momentary, which can be very confusing and frustrating for DJs coming from Traktor who are used to a fully locked, continuous sync.
We know that VirtualDJ is capable of mimicking Traktor’s behavior up to 90%, but it currently requires advanced custom VDJScript commands (combining pitch lock, BPM match, auto-pitch, etc.). As regular users, we do not know how to write scripts, and we are afraid that messing with complex scripting might break our setup or cause unexpected errors during live gigs.
What we are asking for:
We don't want you to remove VirtualDJ’s current momentary Sync for those who like it. Instead, we kindly ask you to consider adding a simple, one-click option in the Settings or Mapping menu—a toggle or preset that automatically links all necessary sync, pitch lock, and master clock behaviors together.
Please remember the users who left Traktor for VirtualDJ! In Traktor, it was just one button and the job was done. We shouldn't have to suffer, search forums, or learn advanced coding just to get a simple, continuous sync experience that we've relied on for years.
Please take care of us former Traktor users so we can enjoy VirtualDJ without the headache of scripting!
Thank you for listening to your community and for your constant support.
Best regards,
Best regards,
