Forum: VirtualDJ Skins
Topic: Time display change on Hot Cue buttons
Anyone knows if it's possible to change these seconds on the Hot Cue pads to HH:MM:SS instead ? Whatever the skin I use I have not found a way to change them.
My brain has a hard time dealing with the running seconds and 1/10 of seconds, I'd perfer HH:MM:SS ;-)
geposted Fri 07 Nov 25 @ 3:43 pm
Looking at the script now,
setting cueDisplay
Thanks, let me know what you come out with.
These are the two where I'd prefer HH:MM:SS when set to "distance":
<cueDisplay modified="yes">distance</cueDisplay>
<savedLoopDisplay modified="yes">distance</savedLoopDisplay>
Any update ? Anyone ?
settings/cuedisplay(drop down arrow) position, that will give you minutes and seconds, although it doesn't countdown it seems
