Topic: Flashing PAD button
I've assigned a prelisten function to a pad button in the PADS EDITOR:
Push Action: prelisten
Color: prelisten ? blink 500ms : off >>The color/LED also works on the screen.
Now I wanted to make the hardware PAD button on my DDJ-800 light up:
In the controller mapping, I assigned the KEY:
LED_KEYBOARD_PAD1 with
prelisten ? color "yellow" : color "green" >> Works!
However, I can't get the LED button on the DDJ-800 to blink while prelisten is activated.
prelisten ? blink 500ms : color "green" >> Doesn't work!
Is the LED not capable of blinking, or is the command incorrect?
Thank you for your help.
geposted 3 hours ago
Blink must be used as query:
prelisten ? blink 500ms ? color "yellow" : color "black" : color "green"
WOW! Thank you so much!! It works perfectly!!
