Topic: MAP DECK COUNTOUR ON RANE ONE MK2
HEY EVERYONE!! Quick question. Does anyone know if it's possible to midi map deck contour on RANE ONE MK@?...I couldn't find it in the options but I just thought I would ask just in case I was missing something. Thanks in advance.
geposted 2 hours ago
Map it to what ?
It is a hardware feature and it doesn't need any mapping to work. It works as is.
In fact if you MIDI map it to something then it will do BOTH.
It will control the contour, plus anything else you assign to it.
