Hello. I am reorganising my library, and I need help. Usually, I hold Shift and use the mouse drag to move songs to another folder, but that moves the song from the original folder to another folder. What I want to do is move the song to another folder, but also keep it in the existing folder. Can I do that easily? Not with Right Click -> Copy to.
geposted 3 hours ago
Just press CTRL instead of SHIFT then..
Standard computer behavior! :)
Oooh, if you are on a MAC then it's CMD for you.. :P
