Request RTL support from VirtualDJ
Can support proper right‑to‑left (RTL) display for Arabic karaoke lyrics
geposted Mon 15 Dec 25 @ 1:13 pm
me too it will be ver useful option for arabic songs
geposted Thu 22 Jan 26 @ 6:08 pm
Still Same problem in the newer version V2026 b9171 ... the system get the correct lyrics and timing but in Arabic we read from Right to Left .. I guess we need fix for this
geposted Fri 20 Feb 26 @ 11:18 pm
i requested that more than once
but am sure the team will fix it
geposted Sat 21 Feb 26 @ 2:28 am
Chiming in - this would be super helpful. Even a manual toggle option would be great.
I found a feature that does work though and is a half decent workaround. The Lyrics function, choosing bottom line, the words actually appear RTL. you can then move the line to the middle of the screen and enlarge the size.
It will only show one line at a time, and no progress color, but it works!
Lyrics - Bottom Line Option - Moved to Middle.
Broken RTL Karaoke
Broken RTL Karaoke
geposted Wed 18 Mar 26 @ 11:42 pm
still no updates on this
geposted Wed 01 Apr 26 @ 8:13 pm
