I downloaded the new update, and the pitch effect is different. No longer is it changing it by semitones, but doing something else entirely. Is there a new effect that can change your song by cents and semitones?
geposted yesterday @ 8:08 pm
legacy is still available, new pitch is a 2 dial affair, dial 2 picks your range related to pitch 0% and then dial 1 picks how far towards dial 2's the key is taken.
See the fx gui to make sense of it.
geposted yesterday @ 8:24 pm
Thanks for the response, how can I access the legacy pitch effect in virtualdj 26?
Some feedback on the new one though: Dial 2's percentage only is plus or minus 25, 50, 75, or 100. Would love to see some more flexibility than that. Also, the song's key indicator does not change, so I don't know what key I am in post fx.
geposted 23 hours ago
You only get -50 & +100 with the old plugin [+-1 oct].
Really all the old plugin did [in most cases] was perform the key_move script [hence why you saw the change] you can use the key section of the gui for that.
New version performs the key transform on the buffer sound not the track, and allows semi tones.
If think there's a key padpage you could use too.
geposted 22 hours ago
Key +1 -1 is also available directly on the interface
geposted 16 hours ago
But I liked with the old one how you could do pitch adjustments in the 0.1-0.9 range. I was wondering how to recreate that in the new update.
geposted 5 hours ago
