Forum: Wishes and new features
Topic: Saving Favorite AI Prompts
I'd like to have a way to save favorite AI Prompts that I can easily access and reissue when I need them. Some examples might be:
1. Latest chart-topping pop song
2. High energy song for the dance floor based on current song
3. Play a compatible track in a similar key
geposted Sat 20 Dec 25 @ 6:42 pm
after you get your ai results right click the ai proms folder and select what you see in the image
and then you get this
your saved results titled by you ai input
Yes. I've seen that. it saves the result, which is cool. However, I am looking for something that would allow me to reissue the same prompt at another time for new results.
Basically you want a history, similar to what happens when clicking in the Google search box - it shows things you've entered previously.
not really a history, because I don't want every prompt as some of them are not worth keeping or they are specific to an event and that moment.
However, others can be reused and produce different results depending on the context like a prompt based on the currently playing track. I would classify what I am looking for is a favorites list that can easily accessed.
