I'm using a ddj800 factory mapping and just updated to the latest VDJ version and now all my effects have suddenly become way to intense and that goes for using pads or beat fx select control?
Also the low cut echo no longer cuts out on max and the echo also isn't functioning as it used to, there is no effect until i turn the fx control to max which cuts 90% of the sound?
geposted 2 hours ago
new effects, look into the fx gui's to see how they're different.
Also look in effect_list
https://www.virtualdj.com/manuals/virtualdj/interface/decks/decksadvanced/effects.html
geposted an hour ago
Cheers for the response but echo wouldn't function if I used the controller fx control knob or the pads?
I checked settings and in the end gave up, rolled back to V2025 B8800 and it all works as it did. It must be a bug issue that needs to be resolved with the current version. The effects that did work e.g reverb, flanger were all too intense with no way to adjust?
geposted 35 minutes ago
