Hi Guys, The problem that i am having is when I search for songs in VDJ V2026 - gl -b8978 my space bar don't work. also if I press the search bar a couple times the search Icon disappears and the fader goes from the side that I have to center position . the program works like a charm but this is the only problem that I have. because as you can see I can type normally in any search I do outside VDJ. Using Macbook Pro 2.2 Quad core, Intel core i7 16 gb ram. please help
geposted 20 hours ago
