I get the auto update bar coming up when i open VDJ. i press the yes button to use now and nothing happens. I close then re-open and it goes through the same process. Is something going on in the background or should it open straight away? Can anybody help?? Thanks in advance
geposted Fri 26 Dec 25 @ 3:42 pm
You can just download the latest version from the wiki.
geposted Fri 26 Dec 25 @ 3:48 pm
Reboot your PC then install from here: https://virtualdj.com/download/build.html
geposted Fri 26 Dec 25 @ 3:51 pm
