I did a wedding last night. During dinner, I used Automix on deck 1 to play a dinner set. During that set, I tried playing a track on deck 2 with the gain down to listen in my headphones. However no audio of the track on deck 2 came through. Earlier, before the wedding started, I could use my headphones on either deck with no issues when I was manually mixing since that’s part my routine smoke testing before an event. It seems that Automix somehow disabled the use of my headphones. To get around this issue, just after dinner music was done, I quickly exited VirtualDJ & then restarted it. Then I manually loaded a track on deck 1 & started dance music, and my headphones worked fine. Today I’ve tried to recreate the issue in my basement, but I can’t get it to do this again. I am on VDJ V2026-m b8978, MacOS Sequoia on my 1 year old MacBook Pro with 36gb of ram. I am using a Pioneer DDJ REV5 controller. I would rather not have to do this again. It was awfully scary. ChatGPT gave me a few things to try, but no luck. Can anyone possibly advise on a good solution or workaround so I can prevent this issue?
geposted yesterday @ 2:45 am
