since downloading vdj 2026 i have transported all my playlists frm a previous version into the new folder in vdj ( why its changed from my documents to app data i'll never know)
when i look in the app data folder all the lists are there, but they will not show in the left hand panel in vdj. i've made sure i havre " full control" in all folders and in have reset root folders but its still not showing. i cant even cteate new playlists? any idea?
geposted 11 hours ago
Based on the Wiki for transferring ti a new computer, the paths that VirtualDJ checks are as follows:
How to check the path VirtualDJ uses is described on the page too.
Based on your report, I assume you are on Windows and using a version of VirtualDJ probably older than 2023 - ensure that you are actually using the correct path (in %USERPROFILE%\AppData\Local\VirtualDJ), and that you backup + remove the contents of the old path.
Also, VirtualDJ has moved to the MyLists structure to represent all lists - one the most significant changes there is that Playlists and Virtual Folders have been merged (now just called a List Folder, and a Playlist is now a List Folder that has order/the order column), and that the entire structure is stored in a different parent folder (VirtualDJ\MyLists parent folder). If I remember correctly (anyone correct me if I'm wrong), VirtualDJ auto converts the old structure to the new one, but anything/any tool that's dependent on the old structure would need a setting set in VirtualDJ (browserShowLegacyM3UPlaylists = yes) to allow it to display the old structure for newer created List Folders with order.
With respect to this:
My guess would be that %USERPROFILE%\AppData is considered the standard location for application-specific configuration data/settings, while %USERPROFILE%\Documents is really just a general storage location for Documents.
I think a similar change, for a similar reason, was made on MacOS too.
geposted 6 hours ago
Usually there's no need to guess paths yourself though.
Either use the built-in backup and restore functionality, or press the Cog in options to open the correct folder.
Hi Vinyltouch,
Thanks for your help..
ive followed the pathway that VDJ gives you in settings / options / settings cog, and i do believe its the correct folder, the playlist folder is there ( see image 2 ) but its still not showing in the window of VDJ, i cant even expand the "my lists " folder. ( see image 3) . i have no idea what i'm doing wrong?
geposted 19 minutes ago
