I have been playing around with the lyrics function today with a keen interest in automatic censoring and helping with wordplay. Everything seemed to be going smoothly and then this evening, I noticed some tracks not populating any lyrics (locally stored, Earth Wind and Fire and Kool and the Gang stuff specifically) and when I went in and clicked on re-analyze, either nothing would happen or I would get the Lyric Extraction in Progress pop-up...and then no lyrics would show up. Is the lyric analysis a server side function and if so, is this something that has a limit on daily requests or perhaps has been experiencing outages or overloads? I'm just trying to understand why it would stop functioning for newly loaded tracks all of the sudden when I was having no issues earlier in the day.
geposted Tue 30 Dec 25 @ 2:17 am
Still finding locally stored files that just will not acquire lyrics or try to get them. Very random feeling, Take On Me by a-ha works with the tidal streamed version but not the local file. Meanwhile Sing a Song by EW&F won't work even with the tidal version. Can someone shed light on why the software seems very arbitrary about which songs it will and won't attempt to analyze?
geposted Wed 31 Dec 25 @ 6:36 pm
ser el mejor de la jusica
geposted Wed 31 Dec 25 @ 6:59 pm
I had the same problem. I used an audio converter and ran the song through it at the same bit rate and it had the lyrics back after I re-analyzed the song. I am not sure what is causing it but this seems to work.
geposted Tue 13 Jan 26 @ 9:07 pm
