I use the Pioneer FLX10 from Pioneer.
When I have set a saved loop, the colour pad is blinking continuously, no matter if the loop is active or not. How is it possible, that the pad isn't blinking anymore, as soon as I deactivate the saved loop?
Saved Loop on: Pad blinking
Saved Loop off: Pad lights up continuously
Thanks for help.
(On my Pioneer SX3 it all worked properly)
Thanks for help.
geposted 6 hours ago
I suggest you look at the mapping for the SX3 to see how it was done.
geposted 5 hours ago
Of course I already did that before, but it didn't help...
I tried a lot of things but nothing worked.
geposted 3 hours ago
