Is there any way to change this for a Stems indicated ( has stems or no stems ) other then using the Pad area? ONLY When a song is in the deck/player
geposted Wed 31 Dec 25 @ 12:28 am
has_stems is the query, the rest is a skin edit, just a visual will do.
geposted Wed 31 Dec 25 @ 2:21 am
If you want to try it..
https://virtualdj.com/plugins/?addonid=81906
It's not enabled by default, but you can use the skin menu button to turn it on:
GTS->Decks->Jog Style->Show Stems
geposted Wed 31 Dec 25 @ 8:24 am
Ill try it thank you
geposted Sat 03 Jan 26 @ 6:26 pm
