I have a Traktor Kontrol S2, I'm running on Windows 11 with the latest VDJ
I have the correct driver controller driver installed, VDJ identifies the controller correctly, all the knobs and sliders interact correctly but when I press Play (the button lights up showing its being pressed) nothing plays or sometimes it will start to play for 2 seconds and stop. I've uninstalled/reinstalled the driver and VDJ to no avail.
geposted 9 hours ago
Turn Vinyl mode off and try again
Does it work now ?
If yes, your controller's jog pressure switch has enough wear to register pressure even if you don't touch the jog, and it needs to get serviced.
Does it work now ?
geposted 3 hours ago
Thank you, you saved my life for a NYE gig tonight!
geposted an hour ago
