On CDJ Export screen, what does the checkbox "Keep Synchronized" exactly? What is the difference with the Cue Sync and Stems sync options in the CDJ key properties?
Also, when there is an error on exporting a playlist (let's a few tracks have broken paths), the error message only shows the first file that failed despite showing a message telling multiple files have failed. This is a bit painful to track all the files that have failed. There is a similar when a playlist could not be synced, the message will only tell "A playlist failed to synchronize" when plugging the key without telling telling which one (I guess this what the "Keep synchronized" checkbox is related to but it's not clear).
geposted 4 days ago @ 10:56 am
'Keep synchronized' means that every time the USB stick is connected to the computer, VirtualDJ will synchronize any changes to the list or folder that was exported.
geposted 4 days ago @ 11:52 am
