Hello,
I have the newest version of VDJ. Earlier I used the hercules dj control instinct p8. It worked perfectly. Bought the home licence to use it with vdj. Havent used it in a while and decided i wanted to pick it up again with a new controller: Numark partymix MK 2.
Now, I cant get it to work. Both the controllers doesnt work anymore. Tried everything from the help pages. Installed the drivers, tried usb 3.0 and 2.0. And everything I could find. I even reset the whole laptop and deleted everything for a fresh start.
If I connect the Numark, I dont get the message that vdj detected new controller. It does show in audio settings. In controller settings, it shows but dont have the image of the controller on the button. Weird thing is, if I go to mappings, it only shows ' ignore' and "custom mapping" (which is empty). No factory default. If I go to controller not showing, and select de Numark partymix mk2, sometimes it shows the factory default mapping, but still doesnt work. Mostly if I select it from there, there is also no factory default.
Can someone help me to get the Numark partymix mk2 to work?
Thanks in advance!
Thanks in advance!
geposted 4 days ago @ 4:11 pm
Sounds like you have disableBuiltInDefinitions enabled, so make sure that's set to no
geposted 4 days ago @ 4:13 pm
Thanks for your response. I checked, but it was already set to 'no'.
Hopefully someone can help me. Thanks in advance
geposted 4 days ago @ 4:57 pm
