can anyone help me out. im trying to connect but its not allowing me to connect to the server. i have 1 account on 2 seperate laptops? looked at my firewall settings and all are ok but cant get past the 'can not connect to server message'
geposted 2 hours ago
Support Staff wrote :
something is blocking VirtualDJ from connecting likely.
If you can not connect (and its not something else, like wrong password).
If you already tried the tool [ For PC: For Mac: ], then check your firewall etc..
If unsuccessful you can contact Support Team here, so they can help you with remote access
https://virtualdj.com/help/
