Forum: Wishes and new features
Topic: Vertical Mode
I don’t know of this would be possible, but most streaming platforms are in VERTICAL MODE. Wouldn’t it be cool is VDJ had this capability (or does it, and I’m missing it)? How much easier would it be to stream directly to TT, FB, IG etc directly from VDJ in a ‘split screen’ with the DJ on top and videos/ lyrics etc playing below. No more need for outside apps (unless going to multiple destinations). Just a suggestion.
geposted 5 hours ago
I'm pretty sure this isn't true - only TikTok and IG (and maybe FB, but it also accepts 16:9) uses a 9:16 aspect ratio. Virtually every other major platform natively accepts 16:9.
They could look at adding native 9:16 though - you'd also need video overlay skins for that case as well.
Yeah, I realize that, but just changing the output option from 16:9 to 9:16 would probably be the easiest… and keep it a camera/ video split screen ONLY configuration to simplify. I definitely would be down for that.
Should already work if you change the resolution of the broadcast output
