It would be preferable that, during decks mixing, the lyrics do not follow the master deck, but instead follow the stems.
For example, when vocals are killed using performance pads or the mixer (EQ mode), the lyrics of the corresponding deck should not be displayed, and the lyrics of the other deck should be shown instead.k should be displayed instead.
This behavior would provide more accurate and intuitive lyric display, especially when using stem-based mixing.
geposted Mon 19 Jan 26 @ 11:12 am
Are you referring to the waveform or the lyrics effect?
The use case for a lot of karaoke people seem to be using the lyric effect to display the lyrics and then disabling the vocal stems, while keeping the lyrics onscreen, to get an on the fly karaoke file. Your suggestion directly breaks that use case (which I thought was the default use case).
While I understand the request form a mixing perspective, that sounds like a showstopper from a karaoke perspective, so probably this should be a new settings option for a user to choose (and the default should probably be what is happening now, since it was released that way and the behavior is reasonable from at least the karaoke perspective).
geposted Mon 19 Jan 26 @ 3:30 pm
I'm referring to the video effect "lyrics" and not the video effect "karaoke"
ps: and yes let it exist as a second option
geposted Mon 19 Jan 26 @ 4:49 pm
If this feature with the lyrics was introduced , it will be very helpful to also have search in lyrics . So if someone asks for a song but only knows some words , you can type those words in the search field and find the song.
geposted Tue 27 Jan 26 @ 6:28 am
You can use AI prompt for that
geposted Tue 27 Jan 26 @ 7:58 am
