Hi, maybe some has time to add this feature and i hope it's not a configuration fault.
I'm used to put additional informations direkt in the filename. But i have always to resize the rename dialogbox (right mouse button - file operation - rename... . The standard size looks for me for old 8.3 char filenames. Now, we have the year 2026 . :-). In my eyes easy solvable, only save the last dialog box size + maybe the relative position on the screen if you can.
Standard popup size:
For example:
For example:
geposted Thu 22 Jan 26 @ 3:58 pm
It's often been requested here for many years, to save the size of popup windows.....
[tumbleweed]
[tumbleweed]
geposted Thu 22 Jan 26 @ 4:13 pm
And BPM editor, POI editor etc .......
geposted Thu 22 Jan 26 @ 4:16 pm
Doesn't sound very exciting. I don't consider my opinion alone to be particularly important. But if it is fundamental company strategy not to implement improvements to the human machine interface, that gives me pause for thought.
And Thx @Groovindj and @Kradcliffe for your comments
geposted Sun 25 Jan 26 @ 4:14 pm
