I work in two venues: one with an XDJ-XZ and another with CDJ-3000 + DJM-900NX2, and I experience the same issue on both setups.
When two tracks are playing and I use the default Stems + FX, especially Vocal Echo or Instrumental Echo, the tracks start to drift out of sync. After applying the effect, I always need to correct the timing with the jog wheel.
The important part is that this problem happens only with the Echo effect. It is not audible inside VirtualDJ itself, but it becomes noticeable only at the mixer’s output.
Because of this, I have to use VDJ 2025 (b8729), where this issue does not happen.
Is there a way to fix or prevent this behavior?
geposted 4 hours ago
