help
geposted 14 hours ago
Hang on a minute while I go get my crystal ball.....
I see in your Account stats we keep in our server, that you are using Stanton DJC-4.
If that is the case, then this device cannot work on newer Mac OS.
I believe not supported in Monteray and later Mac OS
Found this topic with more info https://www.virtualdj.com/forums/221555/VirtualDJ_Technical_Support/djc_4_sound_card_not_appearing_in_audio_settings.html
Looks like an issue with the sound card, but not Midi, not sure. What is your issue exactly ?
geposted 13 hours ago
