I've noticed a new bug in b9209. When I add new tracks and edit them with cues, tags, etc., the "Reread BPM & Tags" function deletes the existing tags.
(see screenshot)
VDJ also currently doesn't read these tags but seems to only use those in the database.xml file.
This file also appears to be written incorrectly, but I haven't verified this. I haven't yet figured out exactly what triggers what.
VDJ then treats the files as new and starts the scan, which currently means that all changes are lost after closing VDJ.
The cues and loops are also lost.
Furthermore, this update doesn't fix the issue where VDJ doesn't close properly and can only be closed by restarting Windows 11.
(see screenshot)
geposted 9 hours ago
A small addition:
0t seems that VDJ simply no longer reads external changes, such as tags, and instead rewrites the track number.
Wherever this comes from – I ALWAYS delete it with mp3Tag BEFORE VDJ even sees this data!
So far, this only affects new files added since the last early version; older files are unaffected.
VDJ also correctly writes the genre tag into the file as usual. However, if I change this in mp3Tag and let VDJ re-read the BPM and tags, it's essentially reset!
geposted 8 hours ago
