Topic: Pitch Range - Lock
Hey!
Pitch Range seems to have a mind of its own. Setting reflect 12.0 but this will wildly update to much larger ranges, all on its own.
How can this pitch range be locked and not allow the system to override it?
geposted Tue 10 Mar 26 @ 8:25 pm
The answer is right below the option you highlighted (set that to No).
[face_palm]
Literally right under my nose.
[/face_palm]
Thank you!
Unrelated but related comment to the @devs - I think there is value in allowing a sync without needing the physical + software pitch range to be adjusted to allow for reaching it physically.
Sometimes you just want a wide pitch sync for a blend, but leave the range unchange for other future songs loaded on the deck (very wide pitch ranges make minor adjustments to wide too).
When loading the next deck with a song, you could just make the software pitch takeover be instant on movement, until the software pitch is back in range (then go back to what the setting is), if the software pitch fader position is found to be out of range of what can be met by the physical pitch fader.
You could maybe even make this a new takeover mode.
Please let me know if this is already achievable too - my impression was that autoPitchRange=yes was required for wide syncs.
