Topic: SyncToy Backup
SyncToy is a free Microsoft utility I have used for many years.
It will synchronize files and folders between two locations.
It works great to keep a safe copy of VDJ on a separate drive of your choice.
Although discontinued, it still gets the job done.
Sync Options:
Echo: New/updated files from left folder are copied to the right.
Contribute: Like Echo, but no files are deleted on the target.
Synchronize: Changes (additions, renames, deletions) in either folder are copied to the other.
Very easy and free method of keeping your files and database safe......
Maybe someone will find it useful.
Kevin
geposted Sat 14 Mar 26 @ 3:52 pm
I use an older version of Allway sync (they went to a subscription in the current version). I did not know that Sync Toy even still worked in Windows 11. That's awesome to know. I keep 4 separate backups of my music these days for safety. Awesome suggestion! Now if we can get people to backup their VirtualDJ folder as well...
I use Synchredible and it's free. Has worked perfectly for many years.
VDJ also has built in backup and restore.
There's also FreeFileSync (open source and free), and if ur a scripter, and comfortable with built-in tools, you might get away with using robocopy.
Hi, im using also Freefilesync for all my backup stuff, easy and fully configurable.
Cheers
Glad i mentioned Sync Toy.....look how many options it sprouted!
Great sharing guys.
