Topic: Zoom issue with b9229
This release has an issue with the zoom function in the horizontal waveform. It crashes reliably when I try to zoom out at the maximum level. It happens both with my skin and with the Default-Pro, and both with the top left GUI zoom control or with my FLX4. It happens also if I go through a GPU or not. Win 11, Surface Pro10.
While I never experienced this exact problem before, I am used to avoid the POI editor and the BPM editor because they often crash in similar fashion. These are not reproducible problems, but had been happening for a while. If they are all using the same graphic engine, I guess there is a bad pointer or a problem with memory management linking these problems.
geposted 5 hours ago
Seems like a Windows only issue - I have no issues with the Horizontal or vertical waveforms at max zoom on Mac (M1 MacBook Pro used to test).
confirmed here, zoom verb seems ok [I have a button that jumps between 2 values] but scroll with mouse or drag zoom slider with mouse crashes.
Only seems to do it if colors is selected. Using beats or shapes doesn't crash (for me anyway)..
