HEllo,
where can i download VD v2026 b9005? i want to go back to it!
problem of hercules mixtable
Thanks!!!
Thanks!!!
geposted Sun 05 Apr 26 @ 6:55 pm
Are you sure the problem is with the build, rather than Windows MIDI 2.0?
geposted Thu 09 Apr 26 @ 10:02 am
the correct answer (as discussed here: https://virtualdj.com/forums/266880/General_Discussion/How_to_revert_back_to_VDJ_2025.html) is just go to https://virtualdj.com/download/build.html and choose the oldver you prefere ;)
geposted Thu 09 Apr 26 @ 10:59 am
If the Hercules controller has stopped working, going back to an earlier build will not help. It's better to install b9245 or newer, and disable MIDI 2.0
geposted Thu 09 Apr 26 @ 11:10 am
but unfortunately most of the older version that were available on the build download subpages are disappearing...
geposted Wed 22 Apr 26 @ 1:21 pm
For a reason. I'm guessing you're just now trying to find an older version that doesn't have the voice drop. Not happening.
geposted Wed 22 Apr 26 @ 2:10 pm
my input on this would be that if it worked on a previous version but not on a newer version then you should probably create a custom mapper for it, ive had issues with hercules devices in the past and just mapped them to suit. always worth a look.
geposted Fri 24 Apr 26 @ 6:34 pm
